Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: TO-20 Pivot Pin and Bushing Questions.
07-16-2012 11:14:48
If it doesn't appear to have any bush then you want the thin bush, the early type. It doesn't matter what engine it is the axles are the same. Early bush was 1-15/16" x 1-25/32" x 1-1/2" long, the axle pin was 4-1/8" long.John(UK)
Kevin Little
07-16-2012 11:21:14
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to John(UK), 07-16-2012 11:14:48
Thanks John! So I can just remove the pin and measure it for length to see which setup I need?
07-16-2012 11:40:59
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to Kevin Little, 07-16-2012 11:21:14
The two bushing are a lot different, one is thin like I said and the other one is quite thick and has a collar on one end, so you can soon tell what you have. I have found an amended size for that Bush I gave you earlier, it is 1-49/64" x 1-29/32" x 1-1/2" I got this one from a TO30 parts list so it should be right.. The Pin you can remove and measure it easily. There are a few different type of bolts that hold the pins in the Axle carrier though which can be confusing..John(UK)
Kevin Little
07-16-2012 12:31:13
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to John(UK), 07-16-2012 11:40:59
Thanks for all your help John. It may be a couple of weeks before I can disassemble the pivot pin, so I'll wait until I do before ordering the replacement parts.
