Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: rear axle seal
07-15-2012 03:20:44
The Hub that holds the Bearing and the outer seal needs pulling off the Shaft after you have drilled the collar and removed it. Can be hard to remove and pressures in excess of 25 tons are often required. The Bearing should be pre-packed and then checked every 12 months and packed again. If you don't do this the Bearing wears and causes wear on the Oil seals. But the seals get hard with age and crack as well. The End Float in the Rear Axle needs adjusting when you replace the Shaft. If you need the information for carrying out this repair, email me...John(UK)
