Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: rear axle seal
samn40
07-15-2012 00:32:39
The outer seal on your later type tractor is to keep grease in and dust out. Usually if you repack your bearing with a good quality grease and fit a new inner seal it will suffice. Reuse all your old shims and then check for free play by pulling the shaft in and out. This is trial and error, removing one shim at a time and tightening at least 3 bolts until it is set correct. make sure, when you are happy with the lack of in-out movement, that when you turn the axle the other side revolves in the opposite direction, if both turn the same way then the axle ends are hitting in the middle and binding. If this is the case you need new bearings. Sam
Copyright © 1997-2015 Yesterday's Tractor Co.
