| Harry Ferguson Tractors Discussion Forum |
Topic: T035 Carb and Air Filter
[Return to Forum]
| Author |
[Modern View]
| JLBeller
07-13-2012 20:01:11
208.81.114.115
I have a 1955 TO 35 that will run for about 15 seconds and then it begins to sputter and die. If you place your hand over the air-intake for a moment and then let off, it catches and runs for another few seconds. If you cup your hand and hold it over the air intake it will run just fine. I"ve tried ajusting the carb. but to no success. Before it began doing this, it would run for several minutes and then choke out. I"ve cleaned and ajusted the carb., replaced plugs, and changed the coil. |
[Reply] [No Email] | |
| 2tractors
07-15-2012 05:18:50
207.144.5.133
Re: T035 Carb and Air Filter in reply to JLBeller, 07-13-2012 20:01:11
| One of the MANY fuel filters is clogged or something inside the tank will float over and block the outlet, check the fuel flow.When you cup the intake its the same as pulling the choke. |
| Trac
07-14-2012 08:03:14
71.53.20.111
| It's been said but it sounds like a fuel issue. Unscrew the shut off valve it may be clogged not letting enough fuel in once it's out you'll see the crud |
| jon corbett
07-14-2012 07:51:40
75.213.54.201
| its a suction problem only.gas cap not vented,fuel system has a plug somewhere,and last u have a bad gasket where carb mounts to manifold.please let us know what u find!(it helps the rest of us) |
| Jerry/MT
07-14-2012 07:14:43
206.183.116.145
| | Your getting it to start and run by hand choking is indicative of weak spark (weak sparks need richer mixtures),inadequate fuel delivery( float setting or fuel delivery blockage) resulting in a lean mixture, a vacuum leak around the carbs metering section, a maladjusted carb or a dirty carb. If you have a good spark(FAT AND BLUISH-WHITE, the color of lightning), then checkthe fuel delivery to the carb. Hold a can under the carb and remove the plug from the carb"s fuel bowl.You should have a CONTINUOUS gush of fuel from the bottom of the carb. If it dribbles or is intermittentent, you need to check the flters in the sedimentbowl/tank valve and the fuel inlet elbow to the carb. If you have adeqate fuel delivery, check the carb mixture adjustments(1-1/4 turns out on the power jet and 3/4 turns out on the idle air). You can check for air leaks( carb shaft seals, carb to manifold gasket, manifold to cylinder head gasket, cracked or rusted) using starting fluid sprayed around these locations with the engine running. When you hit the leak, the engine will speed up momentarily. If that checks out, your carb probably needs a good cleaning esepcially in the area of the idle and transition fuel passages. |
| maxwell99
07-14-2012 06:10:40
208.92.105.34
| when it dies, have you ever pulled a sparkplug wire and turned over the motor to be sure its still firing. you need to this to insure its not sometype electrical problem that is shorting out your system after a short run time. new coil does not auto mean good coil, key switch, loose wire, etc: just be sure you are still getting fire to plugs.probaby not: but at your present state you must suspect everything. most times when it does something as you describe, it's a stopped up carb. (normally when it will run better when you pull the choke (as you are doing with your hand over air inlet) you have a plugged up carb. how long did you let the carb set in the cleaner. did your carb kit come with new floats? once I had a coil that would get hot after a short time and the engine would die, that is why i said to check electrial system first. be sure to post what fixed the tractor as all of us may need the info in the future. did you replace or clean the fuel filter in the carb. at elbow, it can be stopped up.
do you have a good flow of fuel to the carb, that you have a vented fuel tank cap |
| JLBeller
07-15-2012 19:37:03
208.81.114.115
Re: T035 Carb and Air Filter in reply to maxwell99, 07-14-2012 06:10:40
| I've soaked and rebuilt the carb, replaced the plugs and coil, cleaned the air filter and it still does the same thing. I checked the manifold and can't detect any leaks although there is a screw broken off from the manifold where it connects to the exaust pipe. There is a slight chance that the fuel shut off is not working well since it did not appear to be as much fuel as you described coming out. I will recheck. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
