TO-30 Parting Out, 1954
I've decided to part out my old tired TO30, as it was declared it has a bad crank/bearings, and I do not have the where-with-all to fix it. Contact me if you are in need of an old part by eMail with a fair price offered for any part and considering mechanics time to disassemble: [email protected]
http://sites.google.com/site/ihartharvest/home/for-sale/ferguson-to-30-tractor
Thanks.
-WaltZ
Hamburg, PA, USA
You have the where with all, not the get up and go!! All you need to do is drop the oil pan and check the bearings one by one. Don't let someone else spent 30 bucks to fix your problem.PS I just hate to see it go into parts.
Pan's been dropped and inspected already at dealer shop. Told Crank needs turned or replaced, and bearings discovered and replaced.
Oil presure lost, assume oil pump quit, and it began to sing, so I shut it down. They said there was slight water leakage into Cyl. #3 as well. Probably been going on for years.
I've been out of regular employment for over 2.5 years, and don't have the +/-$1500 dollars to go into it as a Do-It-Myself Project, and I've already put $975 into the old Fergy.
(quoted from post at 12:48:29 07/21/12)
Anybody else want anything?
-WaltZ
How much for the oil plug and gasket (washer) that goes with it? If yours is still in good condition, I could sure use one (you can see my other thread about the oil plug battle I'm having). Thanks.
