Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: to20 running
[Return to Forum]
gene zick
07-08-2012 10:20:42
4.244.213.219
I can't get my To 20 tractor to run, it fires but won't run. the plugs, points, rotor etc. are okay Battery is new, alternator is working. Any suggestions? The only thing I haven't checked is the fuel line.
[Reply]   [No Email]
John(UK)
07-09-2012 04:40:03
79.76.254.16
 Re: to20 running in reply to gene zick, 07-08-2012 10:20:42
The fuel is the first thing you should check. remove the drain plug from the bottom of the Carb and allow the fuel to run for 3 or 4 minutes if it will to see if it blocks up after a while. If there is no flow, remove the fuel line at the Carb and there is an elbow that screws into the Carb that the fuel line attaches too. remove the Elbow and blow it out the opposite way to which the fuel normally flows or you will block it permanently. There is a filter inside...John(UK)..fergusontractors@hotmal.com
[Reply]  [No Email]
gene zick
07-09-2012 13:30:48
4.244.213.241
 Re: to20 running in reply to John(UK), 07-09-2012 04:40:03
The first thing I did was to disconnect the fuel line at the carb. The fuel flowed easily. I drained the fuel tank, took the fuel bowl off and cleaned it up. Put it all back together and still won't start. I checked the gap on the plugs and the points. They are good. Any other suggestions? Thanks
[Reply]  [No Email]
John(UK)
07-10-2012 06:23:19
79.76.254.114
 Re: to20 running in reply to gene zick, 07-09-2012 13:30:48
I said earlier about taking the elbow off the carburettor where the fuel line attaches and blow through it the wrong way. You didn't say if the fuel actually went into the carburettor or not only that the fuel ran out of the fuel line.
Is there a good spark? it should be bright BLUE, if it is feeble and yellow try changing the wires on the Coil and see if the spark is any better.John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
Gene zick
07-10-2012 07:28:44
4.244.211.78
 Re: to20 running in reply to John(UK), 07-10-2012 06:23:19
Sorry, I did take the elbow loose and the filter was clear, it appears that a good flow of fuel is getting into the carbuerator. Are you saying to put new wires on the coil? Could the coil be weak?
[Reply]  [No Email]
John(UK)
07-10-2012 07:53:13
79.76.254.114
 Re: to20 running in reply to Gene zick, 07-10-2012 07:28:44
No not saying fit new wires, change the wires from one terminal to the other. and see if the spark is any better or worse. The Coil could break down but usually the Engine will start and then cut out but sometimes they don't even start, only way is to try another Coil if you suspect it. If you have a spark, what colour is it:? it should be bright BLUE not feeble yellow. Have you tried a new condenser, they always give trouble, especially if they are more than a few months old.You can also get the Ignition switch failing, check that the supply to the Coil is good all the time, remove the wire from the Ignition switch to the Coil and check that there is power when you play with the switch..........John(UK)
[Reply]  [No Email]
Gene Zick
07-10-2012 16:03:37
4.244.211.127
 Re: to20 running in reply to John(UK), 07-10-2012 07:53:13
Good News! I ran another check on the wiring. I found a broken connection from the coil to the battery terminal. Thanks for all your help. At least everything got changed, cleaned or checked out.
[Reply]  [No Email]
bobs old iron
07-08-2012 12:14:30
97.124.214.170
check and see if the tank has junk in it to clog cock-pit valve, then check carb fuel bowl if any junk in their,,may have to take carb apart to blow out passages,,,if it runs on spray,,[either,carb cleaner,etc] carb might need rebuilt plus the other sugestions
[Reply]  [No Email]
Trac
07-08-2012 10:57:15
71.53.20.111
Yup sounds like a fuel issue
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
