Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: FE 35 Timing Chain Help
[Return to Forum]
Two Dogs
07-05-2012 10:00:30
173.19.160.83
I have an FE35 standard gasoline engine and my timing chain broke and also wiped out the governor and took a chunk out of the aluminum cover. I have the parts on order. So the question is; how do I go about setting the cam properly? I can see a mark on each sprocket but the cam sprocket can apparently be installed in any of four positions. Thanks, TDF
[Reply]   [No Email]
cdmn
07-06-2012 17:48:47
66.228.249.73
 Re: FE 35 Timing Chain Help in reply to Two Dogs, 07-05-2012 10:00:30
It is likely the governor broke first and then jammed between chain and housing. A very fragile assembly.
[Reply]  [No Email]
John(UK)
07-07-2012 02:22:13
79.76.252.235
 Re: FE 35 Timing Chain Help in reply to cdmn, 07-06-2012 17:48:47
Actually there are more of the Flyweight type fitted than the ball type. What wears the Flyweight Governor is not changing the oil. We have tractors with very high hours but have been serviced properly and they still have the original Governor. So maybe that tells you a story. This flyweight type was used right up until the 87mm engine in the 135
If you prefer the Ball type then fit one..John(UK)..fergusontractors@hotmail.com)
[Reply]  [No Email]
2tractors
07-06-2012 06:36:09
207.144.5.133
I'm doing the same with the fe35. Mine needed the front seal replaced and I discovered the loose chain. They sent me 2 cam sprockets by mistake and the new gear has no marks but John came thru with the info.I hope yours didn't bend valves when it jumped timing.Don't forget the new seal.
[Reply]  [No Email]
Two Dogs
07-06-2012 08:26:25
173.19.160.83
 Re: FE 35 Timing Chain Help in reply to 2tractors, 07-06-2012 06:36:09
2tractors, I will be doing that. Thanks for the reminder. TDF
[Reply]  [No Email]
John(UK)
07-06-2012 04:45:35
79.76.249.194
If you haven't removed the Sprocket from the camshaft then there is no problem, and you just align the scribe marks after making sure that number one piston is at TDC and the Valves on number 4 are just rocking (one is closing as the other is opening). If you have removed it, then it will need re-setting properly.I will tell you now that you will need some concentration while you get it set correctly, but it isn't that bad. More than likely the Governor will also need setting again after all this time.
If you need this info about how to re-set everything, just email me direct at the address below and I will send you the info that you need to do it correctly...John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
Two Dogs
07-06-2012 08:24:24
173.19.160.83
 Re: FE 35 Timing Chain Help in reply to John(UK), 07-06-2012 04:45:35
Thanks John, I received the instructions. Maybe I'll be able to absorb some of it while the parts are on the way. It's people like you and others who make it possible for us to keep this old iron from the Chinese. I'm far from rich but I could go buy a new tractor today. What kind of fun and a sense of accomplishment would there be in that? Thanks again, TDF
[Reply]  [No Email]
Two Dogs
07-06-2012 05:40:54
173.19.160.83
Thanks. It's on the way. (I hope) I'll check with you later today. TDF
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
