| Harry Ferguson Tractors Discussion Forum |
Topic: TO 35 stuck in 1st gear
[Return to Forum]
| Author |
[Modern View]
| Steve K
06-17-2012 14:13:55
166.181.3.219
Greetings gentlemen, My TO 35 is stuck in 1st gear. The lever appears to be in about the neutral possision but the tranny is in 1st gear. H/L lever works freely and tractor operates but I can"t shift to any other gear. I removed filler and tried to move things as previous posts had suggested, but no luck. Any ideas? Thanks in advance. |
| John(UK)
06-18-2012 06:12:04
79.76.246.25
Re: TO 35 stuck in 1st gear in reply to Steve K, 06-17-2012 14:13:55
|  Move the selectors that the bottom of the Gear Lever fits into rather than trying to move a gear If you are stuck in first gear like you say, the selector you want to move is the one furthest away from the oil filler and it will be forward towards the engine, you need to move this one back, level with the other one. To avoid this happening again, you should take your time changing gear, slow the engine revs right down and always make sure that the Clutch is set correctly so that there is no drag on the plate and it is hard to change gear. There should be 3/8" free play in the pedal clearance and you should set this when the tractor is hot. To adjust the clearance, slacken the clamp on the pedal slightly just enough to turn the shaft using a bar through the hole in the shaft, turn it clockwise and keep the pedal fully raised while you do this and then check the free-play, if it is too tight, just strike the pedal with a wrench or small hammer to shock it a little to give extra play. Once you have correct amount, tighten the clamp.If you don't have enough play in the pedal, the throwout bearing will be running all the time and will soon breakdown. I have attached a picture that shows the selectors and you will have a better idea when you have looked at it. You will see the selectors as two square holes, they should be side by side together. If you still have trouble, email me direct and I can send you more information...John(UK)...fergusontractors@hotmail.com |
| Steve K
06-18-2012 07:23:12
66.202.73.37
Re: TO 35 stuck in 1st gear in reply to John(UK), 06-18-2012 06:12:04
| Thank you John UK, the picture is very helpful. Do you think I will be able to get at it through the filler hole or will I need to pull the top off? Thanks again for all your help, the hydraulics are working great that you helped me with a few years ago. |
| John(UK)
06-18-2012 08:56:21
79.76.244.176
Re: TO 35 stuck in 1st gear in reply to Steve K, 06-18-2012 07:23:12
| Glad to hear that your hydraulics are still working OK. Yes you can get to the Selector through the Oil Filler,it's a bit tight but it can be done and its easy once you have done it the first time. Just remember that the position of the bottom end of the selector is directly opposite to where the lever is at the top because it pivots in the middle. Once you get used to that idea you are half-way there. A long screwdriver is useful for this job and not too thick and heavy.No need to remove top cover at all...Let me know if you have problems, email me direct and then I can send whatever info that you need..John(UK)....fergusontractors@hotmail.com |
| Dieseltech
06-17-2012 18:53:30
199.16.223.2
| Place hi-lo in start position, this will remove any gear bind. Shift lever ball is in 2-3 rail slot so you have no neutral crossover with 1st-reverse in 1st gear. Go through oil fill port with a long bar or screwdriver and move the large gear back to neutral. When shift lever will cross back over you have it fixed. This works UNLESS something is broken inside. Had a MH 50 once what had a broken shift fork, was in gear even in neutral and still had lever crossover, when in 2 or 3 engine would die as trans was in 2 gears at once with broken shift fork. |
| Steve K
06-17-2012 19:41:07
166.181.3.173
Re: TO 35 stuck in 1st gear in reply to Dieseltech, 06-17-2012 18:53:30
| Thanks Dieseltech, I'll try again tomorrow. I'm not sure what gear I should be trying to move. There is a larger gear that spins with the engine running and I can spin it with engine off and clutch depressed. But I could not get it to move forward or backwards. Will try again. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
