1952 TO 30. Been in the family since it was new. Was rebuilt back in the 1960's. Last 30 years it has been used for mowing, some dirt work, and finish cut mowing. Started using it to power a brush hog (5 ft) about 3 years ago. Noticed this year that after working it for a couple of hours (For brush hogging) the oil pressure drops from the 20lbs that it has held for years steadily to 0 lbs. When I noticed it was at 0 I went back to the garage and parked it thinking I had destroyed something. Went out after it had cooled off to check some things on it. Checked fluid levels oil ok coolant took about 1/2 gallon. Fired it up and it held the 20 lb pressure again.
Am I working it to hard and over heating everything? The area I brush hog requires me to run in 1st gear and basicily full throttle.
Since it has been 40 plus years since a rebuild is it time for a tear down? Tractor runs great untill I use it hard. Every once in a while number 2 or 3 plug fouls. I clean it up and runs great for a number of months.
Other than brush hogging the tractor is used a couple of times a week for 2 to 3 hours each time.
docgj
docgj
