I have read the instructions from John UK.
I have the PTO cover plate, 2 snap rings, bearing and bearing retainer removed from the tractor - finally.
The input shaft and housing can only come out 1/2" or so.
I am trying to pull the PTO shaft forward, I get about 1/2"
I can push it back maybe an 1"
How much forward do I need to move the shaft in order for the gear to drop?
John(UK) instructions say there is a difference in the PTO shaft - small and large. It says the small shaft requires the transmission to be removed to have access to a retaining ring on the shaft.
