Jeff_fergy20
New User
Hi all, I just purchased a 30 inch reversible dirt scoop. The two lower linkage pins are set about 31+ inches apart and they face inwards.
The problem I’m having is that when I lift the scoop up, the width of the bucket puts strain on the lower linkage arms to the point that they actually bend inwards in the middle- basically at the lift rod connection. This seems to make sense as when you lift the arms without an implement the stroke of the arms is quite wide when lowered and narrows up at top. So, If I’m exceeding the limits of implement width, what are my options to correct this? If I shorten the check chains I assume I will stop the lift sooner thus reducing the inward strain at the top of the stroke, however this would also reduce the height I’d be able to attain to dump materials into another vessel (ie trailer). Is there such a thing as extra long implement pins that would enable me to move the arms in closer together? Are there other options I’m not considering other than modifying my bucket?
Thanks in advance again for any and all advice.
Jeff
Jeff
