257 Roberts
Hey guys. I've owned my 1955 TO-35 for 6 years now. It has always been a good tractor. Every problem I've ever had has been ignition related. Right now I'm trying to narrow down one gremlin that has always affected it.
Heres the deal. Mostly my tractor is used for bush hogging, 1-3 hours at a time. For the first hour or so it runs great. After this, it starts missing and losing power. It does this even with new plugs in it. Disengage the PTO and the problem disappears or at least diminishes to where I don't notice it. The last time I used it, there was a single backfire after I stopped the engine.
The tractor has a Z134 engine with Delco distributor. The plugs are Autolite 388 and I replaced them right before I used it last. The coil, condenser, and points were replaced about 50 hours ago. The cap, rotor, and wires are about 3 years old and free of corrosion or other damage. I set the ignition timing when I replaced the points and condenser. The carburetor mixture screw is set 1-1/8 turns out, which it seems to prefer.
I'm thinking maybe the Autolite 388 plugs are not ideal for this application. According to the Autolite website the 388 is a resistor plug and the hottest they make in this size. One range colder is the 3116, a "power tip" non-resistor plug. Colder still is the 386 resistor plug. I'm thinking that the 388 may be too hot a plug for this application. It runs well for awhile but eventually the hot plug starts misfiring under the load of bush hogging. The hot plug could have caused the backfire when I shut it down last, mabe it "cooked off" the incoming fuel/air to the cylinder.
So, any suggestions here? What plugs do you prefer in your TO-35? Does resistor/non-resistor make any difference in this application? Thanks!
Lance
Lance
