I have a few questions, Does anyone know where to get the seals and gaskets? I think YT has the bushings if needed, any cheaper sources?
Gaskets...
Should there be a gasket between the gear box and the upper support? The parts diagram doesn't show one, but it seems like you need it if you want to keep the oil in. I know there is a gasket between the cover and the box, should there be one between the box and the trans?
If I have to make my own, what should I use (paper, cork) and what thickness?
And does anyone use any sealer with the gaskets or just put them on dry?
Sorry for all the questions.
Gaskets...
