The air breather valve allows warm oil saturated air to be sucked from the valve cover and into the intake manifold for upper cylinder lubrication.
Since the oil saturated air mixes with the petrol/gas from the carburettor should this then result in the engine burning some oil and leaving an oil residue on the plugs?
My original air breather valve was missing and I drilled out a thick brass washer and inserted a stainless pin through it to keep it clean.
Perhaps my hole is a little too large and I end up having a greater flow of oil saturated air than is necessary.
My engine does not visibly burn oil but when I look at my spark plugs they do seem to have some oil residue on them and think that the way the valve system works that this would be normal.
Is it normal for this type of engine to use some oil during use as the clearances used during this era are much larger that the ones in use today?
I know my modern day car never needs an oil top up between oil changes.
Regards Brad
Regards Brad
