Having read the importance of fitting the correct plugs on these old tractors I finally decided to see what plugs my tractor had.
I rebuilt my engine last year and it runs very well. I use it to mainly Slash/Brush Hog and at times I tow a trailer aroung the property.
I did not change my plugs after the rebuild as on the outside they looked as if they were new.
I note Champion L10 was the original (Now L86C) and the equivalent in Bosch is W7A and B6HS in NGK.
I removed my plugs to find NGK B4ES and went to the local spare parts outlet to buy the correct plug.
Champion was not available so I settled for NGK B6HS.
At home I noticed that NGK B6HS is a short threaded (13mm?) plug and that NGK B4ES has the much longer thread.
I fitted the new plugs and cut the grass for 2+ hours and felt no difference but noted at low rpm's the engine was missing. I tried adjusting the mixture to no avail.
Next day I attached my trailer and still noticed that it was missing at lower rpm's.
I then removed the new plugs and refitted the old and then adjusted the mixture and all was back to normal.
I do recall reading that some think that the longer threaded plugs are better for these tractors.
Anyone have any views on this subject?
Regards Brad
Regards Brad
