More/less literally.... see something missing in this picture?
That gear is gone, I found a few metal fragments that look about right for it on the flywheel and still stuck in the starter mechanism but not enough to account for all of it.
So what happened..? I tried starting it and the engine caught, ran for about a second and died. Happens sometimes on a cold start the first time so I thought nothing of it and tried again- this time there was a *clunk* and nothing from the starter. Pushed in the clutch to take some more load off and the starter motor just spun free.
Took the starter off and found what you see in the picture.
Is there anything I might have done wrong to cause that? I can't see what... the engine isn't seized or anything it still turns free.
Second... I bought this starter from this site back in the fall, does this look like a manufacturer defect maybe? Should I be asking for a replacement?
Third.... I've got an old starter with an iffy bendix that will probably work welll enough to start the tractor a couple of times. Is that wise? I'm worried about all the little metal fragments that might be kicking around under the flywheel still. I had plans to try to split it for a new clutch and transmission seal over the summer but I wasn't sure I'd have time or that I wanted to start said project.
In the meantime I have some chores I'd like to get done with this beast...
oh, forgot to add, this is a TO-30
