Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO-20 Timing
Jerry/MT
02-13-2012 15:08:43
You reallly shoul be looking for static timing of 7BTDC not 32BTDC! The advance mechanism will advance the timing as a function of RPM to 32BTDC at 2200 rpm, but you have to statically have 7BTDC and then check it at idle for the same value with a tiing light. The advance doesn"t start to come on til ~700-800 rpm.
2tractors
02-13-2012 15:25:21
 Re: TO-20 Timing in reply to Jerry/MT, 02-13-2012 15:08:43
Your problem is with the water issue, did you try and crank with water in the cylinders or is it still in the gas tank or carb or is the air breather saturated. Timing should not have changed.Squirk a little gas in 2 cylinders and if it tries to fire it's not getting fuel.
Copyright © 1997-2015 Yesterday's Tractor Co.
