Toora Stephen
Hi gang,
Background: My starter wasn't turning over. I realised that the connector to it was a bit loose, so I tried to tighten the nut up. I didn't seem to be tightening so I assumed it was threaded. I tried to take it off but then I realised that the bolt was turning with it. I took the starter out and opened it up and then found...
Problem: The terminal bolt has snapped inside the motor. I need to replace this bolt (or replace the starter housing or the entire starter). I couldn't see an easy way to remove this bolt. Is it possible, and can I get a new one from somewhere?
- TS
- TS
