As a recent first time Ferguson owner there is always something to learn about these old machines.
Since rebuilding my Tea 2085 engine earlier on in the year the tractor has run like a dream and all oil leaks have been corrected bar one.
When ever I finish working the tractor I store it in an enclosed shed and due to habit I place a oil drip tray just in case of an oil leak.
While there have been no engine/transmission/pto leaks I did notice recently an oil leak coming out of the felt plug underneath the carburetor. Since the leak is only a teaspoon or so I was not worried but it did make me think as to where it could be coming from.
It can't be coming from the engine as it can't suck the oil from the engine via the carburetor. I assumed that the oil was the trapped vapor left in the tube coming from the rocker cover in to the valve that screws into the inlet manifold when switched off.
The other day I noticed that the bottom of the oil bath filter sump had an oil leak where it fits on to the main body via the hand screw clamp and was leaking on to the radius arm.
I undid the clamp and the oil was well and truly over the level indicator mark inside. I clearly remember filling the level to the correct mark and could not work out how the oil level had gone up let alone as to where it could come from.
I emptied the oil to the correct level and went off to do other things.
I have found through the passing of time that usually I work things out when I am not thinking about them and that the answers just suddenly come to me (generally speaking).
I find sleep to be very helpful and often any problems I may have are usually answered when I am asleep.
In this instance my mind must have gone back to my school days and "Archimedes Principle of Displacement" came to mind and I realised that the Oil bath filter is sucking in unfiltered air and that the debris filtered out is dropping into the oil sump, causing displacement hence the oil level goes up and the engine sucks a little oil into the rubber air tube and this runs down to the carby. Removal of the rubber inlet hose confirmed this and now the leak has stopped.
My point is that I have only used my tractor for perhaps 10 hours or so since the rebuild in what I consider a very dust free environment but was surprised to see how much debris was trapped at the bottom of the oil bath sump.
No wonder the manual says check and refill each day after use.
Just my experience.
Regards Brad
Just my experience.
Regards Brad
