Hello, forum.
Just got a new to me TO-20 delivered. I grew up on a farm so I know a little about tractors.. not enough.. but at least I know what most of the parts are called.
I have many little things to mess with and ask about. When I first started driving it around the yard it kept stalling out on me. I cleaned some sediment out of the fuel bowl and that didn't help... then I reached in and wiggled the rod that goes from the governor to the carb back and forth a few times and now it seems to be doing OK. Maybe just sticking?
I'm also noticing that the rear brake pedal on the left side is laying flat on the running board and can't be pushed down. Can that be adjusted or is something broken?
Now the big issue is the loader... there's a drip drip leak coming from the front loader pump after shutting down with everything on the ground. Then today when I tried to move a load... maybe only 300lbs or so I couldn't tip the bucket up and it would barely lift up any, I was told oil leaked from the pump as I tried to move the bucket. It moves fine without a load. I'm suspecting maybe the pump needs rebuilt or replaced but I don't know who even made it to start looking for parts. If anyone knows or can help me figure out what's wrong that would be a huge help.. a loader tractor without a working loader is kinda pointless
Oh and one other issue... is there one front tire vs another that's easier to turn with a heavy loader on the front? I'm probably about to replace both of them.
*edit hooray I can use image tags now![/img]
