I have a question that would appear very simple but I'm curious if anyone has any insight as to what might have happened. I finally got around to changing the transmission fluid on my TO30 this past winter. I used what you fine gentlemen on this sight recommended (I think it was 5W-30, I'd have to look back through the posts to be sure) and all was well. But since it has gotten warmer it started leaking out of the foremost drain plug and the PTO. I previoulsy had no issues with the tractor leaking. I have tightened the drain plug as best as I can get it (or without over torquing it anyway). It is not a substanial amount of oil leaking but it did not leak before. I'm sure it is because the oil is thinner than what was previously in it but still doesn't seem right. Thanks in advance.
Shawn
Shawn
