My father gave me a Dearborn 14-16 that we last tried to use on his TO30 in the 1980's. At the time we didn't have a manual and didn't know it needed the extra top link and lift arm brackets. It never worked well, kept kicking out.
25 years later. I have the special bracket for under the left rear axle and last weekend I made a new top link extender bracket and new extensions for the 3 point lift arms so it is now hooked up to my TO20 correctly.
In the distant past someone chopped the cutter bar to approx 5'. I suppose so they could mow ditches or something like that. I picked up a very rough Dearborn 14-15 at auction last year that has a 6' bar I could transfer to the 14-16 OR I could join the good end of the 6' to the chopped up 5' to make a 7'. I was leaning towards making a 7' but I've got so many projects going on concurrently I can probably talk myself into leaving well enough alone for now and just transfer the 6'.
I'd like your thoughts. Also, did the Fergusons handle 7' 14-16 mowers OK? Why was a 6' even offered?
I usually mow wiith a Deere #9 7'mounted behind a Kubota. (That setup works like charm but I like to experiment)
