Sherwood Bass
New User
Lift would go up when you engage pto. not very strong. Took pump completely apart. Soaked/cleaned, replaced O rings, put back together, added freah fluid and engaged pto. Lift went all the way up and seemed to be strong. However, it will not come down. In or out of gear. Found a spring in the bottom of the pump housing and a another part near the drain plug. This part is a about 3" long with a hole in the middle, slightly curved knobs on each end.
Also there is a small shaft that runs thru the bottom of the pump housing with a keyway attached to on end and a round valve type peaice on the other. There was nothing to keep this shaft from sliding in and out.
any ideas?
any ideas?
