Good day folks
Following on my queries re my TED 20, and the starting problems I had, herewith some feedback
I managed to get the thing going, after much frustration, and completed the mowing of my bottom field. I noticed the oil pressure dropping off as the engine started heating up (it reached 90 deg on the gauge, which gets its data from the top radiator tank). Oil press dropped off to about 20 - 25 pounds.
The next day I wanted to cut another smaller area of grass, but the tractor wouldn't run for more than about 30 seconds before cutting out. I had to crank it quite a bit on each occasion to get it going again. Between home renovations and work I haven't yet had the time to have a look at it again.
Yesterday I delivered a load of rubber belting to a customer, and saw a rather dilapidated old TE standing behind his shed doing nothing more than rusting away. Closer inspection showed it to be a TEA-20 (S/N 76718), manufactured in 1949. I chatted a bit with him about it, and he reckons that if I make him an offer that neither of us really understand, he'll be willing to let it go. There is a new(ish) alternator on it, and a starter with solenoid attached. Everything else appears to be original, with the exception of the steering wheel (not sure what it is, where it came from, or even if the wheel fits the shaft or was force-fitted), but I'm keen to get hold of this beastie as well.
The front tyres are almost new (at a cost of S A Rand 800-00 [roughly US$120-00] per tyre), and one rear is almost new, the other rather old and cracked, but with an equal amount of tread remaining. Exhaust is also in good condition (better than my TED). It makes sense to buy this tractor for as little as I can, and use both tractors then to get one running decently, while I slowly rebuild the other.
The owner did mention that it didn't have the power to plow anymore, but was still quite happy with a trailer or a mower behind it.
I guess what I'm really saying here is "Brace yourselves for a few more question and answer sessions".
