Toora Stephen
Me again.
This time my 1951 TED20 won't start. The first thing I checked was the carby because I had recently cleaned up all the spark plugs and I was pretty sure that side of things was working OK. Sure enough, when I open the drain screw, no fuel comes out. Not a drop. Usually even when it is blocked a small trickle comes out. There is fuel getting to the top of the carb, but not to the bottom.
So what is it likely to be? Is the float stuck? Is there a blockage within the carb? What is the best procedure to find out?
- TS
- TS
