mooseracing
While out brush hogging, only thing I have that works the PTO, once and awhile when the blades go to spin back up the pto will make what sounds like a light grinding noise. Different sounding then the transmissions gears but I would definitely say grinding.
It doesn't do this with the finish mower. The clutch on the brush hog is new and is slipping when this happens on the tractor. The blades won't be spinning at all but the pto shaft is spinning, and once that blades start to spin up it happens.
Ideas?
Ideas?
