Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
3 point won't go down on my TO-30
733Memphis
04-14-2010 08:30:59
Where do I start to trouble shoot the problem when the 3 point will not go down no matter where I move the control lever? The 3 point control lever moves freely but does nothing. The only way to lower the 3 point is to disengage the PTO and wait and eventually after 10 minuites or so the 3 point will go down. Then as soon as I engage the PTO the 3 point goes up and will not go down. Any help on where to start on this problem will be greatly appreciated.
Thanks,
Eric
Fred Martin
04-15-2010 18:31:56
 Re: 3 point won't go down on my TO-30 in reply to 733Memphis, 04-14-2010 08:30:59
I was bush hogging with a 9N Ford one time about half asleep and all of a sudden I heard the PTO shaft hitting the mower as if I had lifted it too high. Kicked the PTO out of gear and ran it to the barn. Tore into it and the linkage going down to the control valve had a pin that the cotter had worked out and the pin was in the sump. Replaced pin and new cotter pin and all was well. Without the pin in place, it wouldn't go down. I would guess thats what is wrong with yours. Post back and let the board know if thats what it is. ohfred
Richard L
04-14-2010 09:42:35
Go to http://www.fergusonenthusiasts.com then click on "Restoration Helps" then look for the subject you are posting about.
733Memphis
05-10-2010 20:55:12
 Re: 3 point won't go down on my TO-30 in reply to Richard L, 04-14-2010 09:42:35
Richard L said: (quoted from post at 09:42:35 04/14/10) Go to http://www.fergusonenthusiasts.com then click on "Restoration Helps" then look for the subject you are posting about.
Thanks, I went to the fergusonenthusiasts web site and found some information about my 3 point lift problem and now after inspection believe a spring is broken holding the control yoke to the control valve.
This control valve is at the bottom of the case and hard to see and the manual does not have a good picture of this area. Does anyone have a good picture, drawing or preferable a exploded view of the hydraulic pump and related linkage???
Thanks, Eric
Copyright © 1997-2015 Yesterday's Tractor Co.
