Cryptkeeper
I parked the puppy and it wont start.
It is a 51 TO-30. I had the carb rebuilt, cleaned the fuel filters, replaced the coil, adjusted the points to .015. Replaced the rotor and cap (sloppy fit). I have fire at the plugs, fuel drains good (steady stream) at the bottom of the MS carb. The plugs are ok and have been set at .022. I adjusted the main jet out 1.5 turns, the idle jet out 1 turn. It has been modified to 12 volt and I see NO regulator on this puppy, but it ran fine last week. I can see sparking at the points (they are clean). I will replace the condenser tomorrow.
Need some help from you gentlemen. I received a GREAT deal of help on an old 9N I rebuilt.
Any ideas on what to do next?
Thx in advance fellas
