Toora Stephen
I finally got around to attempting to fix a long-term problem with my 1951 TED20 - that of the cylinder liners sitting too low in the block. This (I have been led to believe) has caused the head gasket to blow several times.
Once I got the liners out, this is what I found:
:-} A big mess of dirt and sludge, and virtually no sign of the gaskets that must have once been there!
Having cleaned it out, placed the new gaskets, replaced the liners, replaced the cylinders and put it all back together again - she started right up. After running for a short time I noticed a small amount of water seeping out from the corners of the head gasket. I was worried that perhaps this time I had left the cylinder liners sitting too high in the block. I retensioned the head to the maximum in the torque range and that seemed to fix the problem.
I worked the tractor hard for about half an hour and it seemed fine... certainly the cooling system was working better than ever before. In fact the temperature never rose much above the low end of the operating range. If anything, I would have preferred that it got a bit hotter. The oil pressure also sat towards the bottom of the operating range - not ideal, but it seems to be normal for this tractor.
Overall I'm happy with the results so far. I will check the head tension and valve clearances again next time I get a chance - and hope that this time I have a working tractor for more than a few hours!
- TS
- TS
