Last time I used the tractor the clutch slipped a little on steep grades(mowing). Owners manual explains in very little detail on how to adjust the clutch. There is a hole in the end of the shaft that the clutch pedal is attached to and a bolt to loosen to adjust the pedal. Do I need to loosen the bolt and put a bar through the hole and turn the shaft? If so which way clockwise or counter clockwise? Or do I just loosen the bolt and turn the pedal? I appreciate any and all comments as we use the tractor four or five times a week for a number of chores. Don't want to have to replace the clutch because of lack of maintenance.
Docgj
Docgj
