TO-20 Hydraulic Pump Bushing
ScottB in IN
New User
I have pulled my Hydraulic pump and I found that the Bronze bushing that the PTO rides in is cracked. It looks like I have to disasemble the pump the get to this. I am assuming that the gaskets have to be replaced when I re-asseble the pump. I did not intend on rebuilding as it seems to be working fine. Can I get just a gasket kit for the pump? I would hate to re-use the gaskets as my old shop teacher used to tell me: "...do you reuse toilet paper..."
thanks!!! :D
These bushings are available new from agco, Bereco, and sparex dealers. The only seals are a couple of o-rings on the pump housings. These are also available.
The pump-to diff. case gasket is also available.
Jeff
You can get all the parts you need just as you want them from various places, you can get them here on YT Forum too, look on the left of the page for parts and pick out your tractor model....John
