1755
I dont know if this is the right croud to ask but I am hoping some one might know if a Ferguson 20 3pt hay rake parts will inter change with a Massey Ferguson 20 3pt hay rake I bought a Ferguson 20 on a sail and it needs some parts and the dealer looked it up and found a MF 20 and that is what he is using the oporators manual shows a difernt rake the ends that the bars bolt to on mine is all cast one pise with the hub and the book shows a heavy tin wheel bolted to a center cast hub but the fram and other stuff look about the same the teeth that I got from them look like the ones that fit my MF 36 even thow they are not the same part number the Ferguson ones are bent just a bit diferent I have not tried them on the rake yet but I am wandering if the belt is going to be right befor I get a bunch of parts I cant use I thought I would ask thanks Thomas
Yeah, seems like no rake people on here, try going over to discussions, and ask on 'implement alley'. Is this a pto/ground speed drive rake? I'd like to find one just see it work, I liked my ground drive new idea, except for the 3x38 tires it needed. good luck with it.
