Front End Loader for a Ferguson TO-30 Tractor
Jthrse
New User
Hello I am looking for a Front End Loader for my Ferguson TO-30 Tractor. Can ony one tell me at least a model number for a loader that will fit my tractor?
J, I can't help you however one thing that others will like to know is where you are located as that could help a lot. Richard
I don't want to be a wet blanket but the TO-20 & -30 really aren't designed to take a FEL. The ones I have seen put loads into the engine flange/bell housing and the tractor was not designed for this. And without power steering they are really hard to handle. The access for routine maintenance is atrocious becasue the hood can't be raised. If you really need a FEL get a tractor that can really handle one and that has power steering.
Opinions are like belly buttons-everybody's got one. This is mine on this subject. Your tractor, your $'s, your choice.
Agree 120% I have a MF-35 with no power steering and can hardly move it.
Would not put one on a TO-20---30 unless it was real light and you don't want to do any work with it.
Ron L.
P.S. Have a TO-20==30 also, so I am not talking threw my ash.Or trying to sell you anything.
As mentioned, the TO-20/30 tractors are not ideal for loaders. However, if you have good wide front tires pumped up to max, loaded rear tires, a heavy implement on the rear (I use a dump box which I can fill with rocks), and a loader with front pump so you can still use your three point hitch normally, they work ok. I have a Wagner WM3, and it is a strong loader and fits the 30. Basically any loader that fits a Ford 8N or 9N will also fit the 20 and 30. Oh yeah, one more thing, I have a cut hood so I can remove the top of the hood (three latches) and get to the fuel and radiator caps and the battery. If your tractor is going to be shedded all the time you can just remove the hood entirely I suppose.
