No.1 Piston ring showing on downstroke
covert42
I think I found my binding issue the No.1 piston leans more in one direction towards the wall and you can see the ring on the down stroke what would cause this.
Is the piston installed in the correct orientation? Is it the correct size (did you actually measure it)? Have you measured the bore? Sam
Could be a large part of the piston skirt has broken off on one side. My TO20 had that happen to the previous owner. Have you pulled the pan and had a look from the bottom?
Dan
