I had the starter tested at the Massy shop I got it at. Also load tested the battery. The starter tested fine. Battery also tested good. A compression check was near impossible, every time I put the gauge in, the engine did not want to crank over. I pulled the valve cover and head off to look at the pistons. There was a hint of moisture on some of the pistons. I keep the electrical system on and tried to start the tractor. Sometimes I could get the pistons moving other times not. There is some play in the main pulley back and forth maybe 1/8 an inch or so. What is my next step, should I drop the oil pan and pull the pistons?
