In two weeks I will have just one last opportunity to work on my TEA 20 before the cabin is closed up for the winter and the old girl is put up in her garage til spring.
As part of my ongoing investigation into engine noises (documented ad nauseum elsewhere on this board) I need to remove the head. I also want get get the pan off and remove the oil pump. Both the head and pump I want to take home with me.
As I will only have limited hours to do all this, does anyone know if I can I save some time by removing the head with the valve train, manifold, and carb etc in place, then seperate everything at my leisure at home?
I can probably get a wrench on that row of head bolts which are directly under the rocker assembly, so hopefully that won't be a problem. I'm also assuming that the head will lift off the pushrods without an issue and they will just remain in their bores for numbering and removal last. Governor, carb linkages and fuel line too, of course.
Is there anything else anyone can see that would prevent this approach?
