An update for you all. The good news is I seem to be ruling out potential sources for the engine knock. The bad news is it's the cheap stuff that's getting ruled out!
I adjusted the valve clearance this past weekend which cut down on a lot of the racket that was making the knocking hard to locate precisely.
Now it's pretty clear it seems to be the cylinder closest to the battery, part way down the block, directly to the right of the oil filler. Perhaps a wrist pin then?
So I would cautiously say at this point I can also rule out:
-governor
-exhaust (although I did discover a big bead of weld on the exhaust manifold...)
I also tried the plug pulling exercise again too and noted that while not much difference was to be heard when pulling the plug with the engine running, there was a bigger difference if I stopped the engine, pulled the plug, then started. By doing that I noted the knocking was much quieter when running on three cylinders. When I stopped the engine again and reattached the plug wire and restarted, the noise came back.
Anyway, two more videos posted for those interested. First running with the fuel tank and rocker cover off before the valve adjustment, second after the adjustment, including segments with three cylinders firing versus four. The knocking is easiest to hear during the segment with the engine running with the rocker cover back on.
One other item of note -- the pushrods are not rotating on a couple of valves -- you can see it in the video. Is this serious?
As before, all opinions welcome. Thanks to everyone for their input.
As for next steps, if I drop the pan, move the piston to the bottom of its stroke and try to wiggle the con rod, will that tell me anything conclusive?
Before adjustment
http://www.youtube.com/watch?v=u84YcKyZ7AA
After adjustment
http://www.youtube.com/watch?v=HCjworKPXDA
-governor
Before adjustment
After adjustment
