I'm hoping this weekend to get to some of those oil pressure and clatter diagnostics on the old TEA20 I've posted about recently.
In order to get the thing to run without the rocker cover I need to remove the tank and set up some kind of remote fuel arrangement (as well as block off the breather pipe).
Can anyone tell me what the size of the following fittings are?
-sediment bowl fitting into tank
-sediment bowl output to fuel line
-fuel line into carb fitting
I was thinking of canabalizing my lawn mower for the gas tank and fitting some rubber gas line tubing over either the metal fuel line at the sediment bowl and clamping against the threads or buying a small fittting for the carb and connecting the same way there. Thoughts? Anyone done this before?
Should hold for the short period I need it to run but I think I'll have a fire extinguisher on hand for this exercise anyway...
