Not sure if axle is the correct term but it's the adjustable, multi-hole beam which allows you to widen or narrow the track of the front wheels.
I don't want to change the track width but do want to remove one bolt on each side and shift them as I've read here and elsewhere the two bolts on either side should not be immediately adjacent to each other. The risk of shearing them is greater I believe unless they are spaced at least a hole apart.
Anyway...the tractor is a few hundred miles away so can't run out and check but I want to buy a couple of sockets and a breaker bar to tackle them this weekend.
Anyone know those two sizes offhand?
Thanks :lol:
Thanks :lol:
