Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Ferguson TO identification
Jack Purkiss
08-12-2008 09:27:32
The ID plate at the steering column reads Harry Ferguson, serial #47953. This doesn"t show up on TO 20 or 30 ID lists. It does show as a 1941 Ford-Ferguson on the Ford-Ferguson ID list. The plate reads Harry Ferguson not Ford. All castings lead with TO. Is my tractor Ford-Ferguson or Harry Ferguson? Jack
Jeff-oh
08-12-2008 12:08:32
 Re: Ferguson TO identification in reply to Jack Purkiss, 08-12-2008 09:27:32
If you have the ID plate, then printed on the plate to the left should be the letters "TO" or "TE". Based on the number it is not a TO-30. TO-30 s/n STARTED AT 60,000. Both the TE-20 and the TO-20 could have a SN in the 47,953 range. TE's ended with 48,000.
Since your casting start with TO then you have a 1951- TO-20 Manufactured by Harry Ferguson Inc. in Detroit, Mi.
Jeff
Jeff-oh
08-12-2008 12:09:24
 Re: Ferguson TO identification in reply to Jeff-oh, 08-12-2008 12:08:32
The SN list can be confusing but the ending SN for 1951 TO-20's was 59,999.
JerryMT
08-12-2008 20:38:03
 Re: Ferguson TO identification in reply to Jeff-oh, 08-12-2008 12:09:24
I hate to be picky but it's my understanding that the last TO-20 was TO 60000. The first TO-30 was TO 60001 and went to TO 140000.
Jeff-oh
08-13-2008 06:53:20
 Re: Ferguson TO identification in reply to JerryMT, 08-12-2008 20:38:03
I didn't check but your right.
phil(va)
08-12-2008 10:15:35
If you go to the serial number list on the left column on this page and drill to Ferguson and then to TO-20 you will see it is a 1951 TO-20. And fyi, if it says Harry, it ain't Henry.
Jeff-oh
08-12-2008 12:02:54
 Re: Ferguson TO identification in reply to phil(va), 08-12-2008 10:15:35
Where'd you read Henry?
mark from the fort
08-12-2008 09:46:16
look down on the side of your engine under the distributer.
If it says Z120______ then it is a TO20 Z129______ TO30 Z134______ TO35
external oil filter-TO30
ricky green
08-12-2008 09:39:50
Good luck my to20 has parts that should bee on a to 30 , from all the inf I can peice together, Mine has a external oil filter, which I was told shouldnt be that way on ato20 motor
