Tractor back together I hope with the correct timing gears. After reading on here about how much a compression test will tell you about the engine I did one - actually several. Engine at operating temp, air intake non-restrictive, throttle plate open - I think, and oil squirted into the cylinders. The results - 1 is 85#, 2 is 25#, 3 is 120#, 4 is 120#. I obviously have some problems. My guess is some sort of valve problem, and/or rings need to be replaced.
Just wanted to hear what you all had to say before I started in on this.
Thanks, Stan
Thanks, Stan
