Auxillary Transmissions?
motorv8N
11-04-2007 20:43:33
Are there any transmissions for Fergusons such as the Sherman hi/lo units such as were available for the Ford N series machines? I haven't seen anything similar mentioned for the Fergies.
Matt L
11-06-2007 10:44:12
 Re: Auxillary Transmissions? in reply to motorv8N, 11-04-2007 20:43:33
Heres the differences in the shifter covers.
third party image
third party image
Jim in OH
11-06-2007 09:15:53
 Re: Auxillary Transmissions? in reply to ron8n9n, 11-04-2007 20:43:33
motorv8N said: (quoted from post at 20:14:36 11/05/07) are there blanks in the casting one punches out for the lever or do you have to actually drill a hole "freehand" as it were?
No blanks... If using the Ford version, there are patterns available (call John Smith)... If you are using the Ferguson version, the hole is in a slightly different place and I think the the Ford pattern is useless... You will have to determine where to cut... I can't help but maybe others can.. Jim
motorv8N
11-05-2007 19:14:36
Thanks for all the info guys, and John Smith's site is a fascinating read. A question remains.
For those transmissions like the Sherman which fit inside the main tractor casing, are there blanks in the casting one punches out for the lever or do you have to actually drill a hole "freehand" as it were?
Jim in OH
11-05-2007 14:46:21
Here are a couple of links to past posts.. the first goes back almost two years...to January 2006.
Link
Link
Jim in OH
11-05-2007 14:29:09
 Re: Auxillary Transmissions? in reply to John (TR), 11-04-2007 20:43:33
Matt L said: (quoted from post at 12:09:58 11/05/07) The ford sherman can be made to work, but it needs a ferguson sherman top and the case mod'd. the linkage be changed to work with the start feature...
I must be too close to the mountains....
Berryville
11-05-2007 12:11:53
 Re: Auxillary Transmissions? in reply to CPD Sarge, 11-04-2007 20:43:33
Jeff-oh said: (quoted from post at 20:43:47 11/05/07) The Starter for the Fergusons was engaged with the gear shift. The "S" position on the shifter. Yours may have been over ridden/ replaced with another starter switch. How do you start you machine.
on the TE
1 3 S
2 4 R
OK thats what's the "S" is for.... third party image
I start mine by turning the key..... third party image
Pete
Still learning
Jeff-oh
11-05-2007 12:09:01
The Sherman Brothers and Hupp made a high low transmission gearbox. Ferguson also made one, but they were only offered for the TE's.
Lance J.
11-05-2007 11:19:14
It seems to me that the easiest thing to do would be to move up to a TO-35, MF-35, or F40. In the current issue of Ferguson Furrows there are a few running TO-35"s and F40"s for sale.
Matt L
11-05-2007 11:09:58
Search the parts and pieces section under my name - theres pics of the differences
Berryville
11-05-2007 09:18:05
 Re: Auxillary Transmissions? in reply to John (Ohio), 11-04-2007 20:43:33
"gear shift start function"?
Pete
Jim in OH said: (quoted from post at 15:18:41 11/05/07)
motorv8N said: (quoted from post at 21:43:33 11/04/07) Are there any transmissions for Fergusons such as the Sherman hi/lo units such as were available for the Ford N series machines? I haven't seen anything similar mentioned for the Fergies.
A version of the Sherman Hi/Lo was made specifically for the Ferguson. And the same Sherman for the Ford 8N will also work in a Ferguson if you give up the gear shift start function. However, if you want to retain the gear shift start feature of the Ferguson, you must have the Ferguson version. The only difference is the top casting which moves the shift lever and makes room for the gear shift starting components. Search for sherman here.. also John Smith at the 8N board can probably help. JIm
Jeff-oh
11-05-2007 11:43:47
 Re: Auxillary Transmissions? in reply to Berryville, 11-05-2007 09:18:05
on the TE
1 3 S
2 4 R
Jim in OH
11-05-2007 06:18:41
 Re: Auxillary Transmissions? in reply to Duner Wi, 11-04-2007 20:43:33
Bob (Aust)
11-05-2007 01:20:39
Ferguson produced an optional reduction gear box which fitted between the existing gear box and the diff and "stretched" the tractor around six inches. John (UK) will have the details.
They are rare and expensive. I can't find one for sale in Australia.
The Howard reduction box has problems not the least of which are no parts availability! Not one of the better Aussie inventions.
Bruce(OR)
11-04-2007 22:02:12
I have a "50 TO-20 with a Howard gear reducer and a Hupp Hi/Lo. The Hupp is equivelant to the Sherman. Only a bit more rare and spendy.
