Litle more + To crank safely (if ignition timing is OK) Slowly turn the engine with crank Stop when you feel resistance this is the beginning of the compression cycle of one of the cylinders pull the crank just enough to disengage from pulley notches put the crank handle down 90 degrees compared to floor reengage in the notches and pull the handle firmly upwards keeping your thumb around the handle. This wil permit you to have strongest pull on crank and if however the engine kicks the handle will escape from your hand downwards dont forget to put your thumb around the handle if the handle escapes you will be safe. Never cranck horizontally or downward by pushing action..if engine kicks you know the rest..... The cranking travel should be pulling upwards aprox from 7 o'clock to 10 o'clock compared to a watch. After each try.. replace the crank same as above ad retry one compression cycle at a time on a 4 cylinder engine there is 2 compression cycle by turn. It seems to be a long romance to explain safe crancking but seems to me realy important..bigger is the engine bigger is the danger. Good "safe" tractoring" Joe Ferguson
