Tire pressure
Boyde from Bram
11-03-2006 08:12:38
I have a TEA20.
How much air pressure do you put in the front and rear tires?
Regards
B.
John (UK)
11-03-2006 11:27:19
 Re: Tire pressure in reply to Boyde from Brampton, 11-03-2006 08:12:38
Front, normal use 26psi with loader 35psi
Rear,normal use 12psi, in wet ground drop to 10psi so the tread will flatten more and give a bigger footprint in contact with the ground. If you have them too hard they will just run on the centre of the tread pattern which will wear it away and not give a lot of grip either.
Jeff-oh
11-03-2006 08:25:39
Fronts: 24 to 28 PSI
Rears: 14 to 16 PSI
