TEA20 post hole digger to fit a FE35
JohnPom
Hi,
The post hole digger needs some alterations and I wonder if anybody here knows them?
1st/ The mount on the tractor hits the top of the arms when raising them.
2nd/ The mounting holes on the arms have to be moved as the arm jams and cant be raised.
Ignore that arm attached.
Will the center to center distance on the lift arms make a difference?
TEA-20 may not be the same as a MF 35.........
Bob. Owner TEA-20 & MF FE 35 X
I am fortunate enough to have a Ferguson publication called Implement and Accessory adaptation for 20 /35 tractors John Pom .
It explains that later lift arms were modified to suit both tractors and that a kit was available to adapt early lift arms to suit . This comprised of a set of lift arm extensions an elongated pto shaft and a slip clutch , presumably to handle the extra power of the 35 .
Sorry John , that's all I have , no dimensions .
But with some creative temporary welding it should be possible to determine the length . It seems from the information bulletin that lengthening the arms is all that's necessary to correct the geometry.
