Re: TO 20 Won’t Turn Over
FT3
09-23-2018 16:02:34
Replaced the negative battery cable.
Jumper cables from my pickup attached to ends of battery cables that are disconnected from the battery will engage the starter.
Connected battery cables to battery and will not engage starter.
Removed battery, put in a car and it started the car just fine.
I’m not sure what to try next?
old
09-23-2018 17:23:14
 Re: TO 20 Won’t Turn Over in reply to FT3, 09-23-2018 16:02:34
Try a new battery cable on the + side. Also double and triple check every connection. On one like your having I use a small wire and jump form the battery cable to ground to make sure you get sparks. No sparks poor connection
FT3
09-30-2018 10:10:27
 Re: TO 20 Won’t Turn Over in reply to old, 09-23-2018 17:23:14
I replaced the positive battery cable and it turned over as it should.
Thank you all for your help!
