Re: TO 20 Won’t Turn Over
FT3
09-22-2018 15:46:51
So are you saying that the resistor should have no impact on the starter engaging when the shift lever is moved into the “s” position.
old
09-22-2018 17:42:20
 Re: TO 20 Won’t Turn Over in reply to FT3, 09-22-2018 15:46:51
Yes resister is in the ignition circuit between the ignition switch and the coil
Tom h.
09-22-2018 17:28:48
That’s correct, the resistor is used to reduce the 12 volt system to 6 volts at the coil. Otherwise you would have had to change to a 12 volt coil. A way to see if the starter is working, make sure the transmission is in neutral and use a wrench or large screw driver to jump the two terminals that the starter wire and battery wire are connected to. If this make the starter turn then the switch is either out of adjustment or bad. Usually it is out of adjustment. Loosen the 4 bolts move the plate forward with a pry bar or screw driver tighten and try again. Be careful when prying the battery post is still powered.
