Hello,
We have a ?49 TO 20. It?s been converted to 12v. The ceramic ballast resistor below the battery broke and I replaced it. The tractor won?t turn over at all now. It has the shift lever start.
Battery is 100% charged. Battery terminals clean and bright. Battery cables clean and tight on each end. New starter switch.
Jumper cable attached to starter will turn it over.
Can anyone give me an idea of what to try next please?
I?m thinking it has something to do with the resistor wiring, as that is the only thing that has changed since it last started, but I don?t understand what it does or how exactly it is supposed to be wired...
Thank you for your help!
Rick
Rick
