Live hydrolics on a TO30?
Can this be done? If so what do I need and how much would it cost? Love my ferguson tractor and this would top it off!!
Sherman built a live pto add on. Not many out there. I have one on a 30 and it;s
nice. Has lever on left side seat that you pull to stop tractor and let lift and pto
work. Maybe someone will have one for sale on discussion. The one I have is only 2 I
have seen in person.
Locate TOH on a tractor board. He might be over on the 9N board. He makes an aftermarket add on kit. Not quite as sanitary as the Sherman but
it does the trick. You will have to mod it to fit yer Fergy.
You might also consider a front mount pump driven off the engine.
Depending on what you are powering, you can size the pump to get the speed you want.
