FE35 odd piston
Danish
New User
Hi all
So, I have pulled the pistons from my FE35 grey/gold gasonline.
I am a bit surprised since they dont look anything like the ones found in numerous piston-kits you can buy.
Can anyone identify the piston (image) as a original ferguson FE35 part?
Regards
Mark
I don't know that tractor as such but very likely to be the factory piston that was installed when new. Many old engines used the 4 ring pistons and the 4th ring sat low on the piston like your does
Ok, thank you very much for your input.
I was somewhat surpriced by all the cutouts in the piston. It seems to pose a huge blowby risk.
Regards
Mark
Those cut out cause no blow by since the upper 2 rings are the compression rings and th lower 2 are oil rings. The cuts out just are there so oil does not build up between the lower oil ring an the upper oil ring
